Redstone (Fast Ring) Build Issues
slooksterpsv
348
Why not start a thread so we can post any issues we've had with the Redstone build of W10M:
Build 14267.1004
1) Sometimes after using headphones when the ringer is down, the ringer will show the volume, but still be turned off. - Just turn down volume then turn it up.
2) Sometimes after using headphones: you can't change the ringer volume. Restart may be necessary.
3) Spotify still doesn't detect data over cellular and requires a restart.
4) Store downloads/updates sometimes show 0.1/0.1 and goes up 0.2/0.2, 6.5/6.5, instead of a normal 0.5/6.5 setting
5) Store sometimes crashes upon opening requiring you to open it again.
Chuck Pedretti
18
Latest Redstone release messes up push notifications with Band 2. No amount of resetting of the band, app or phone makes the problem go away until you reload the prod version of WP 10
slooksterpsv
348
Build 14291.1001
1) Messages will sometimes go into Landscape mode when switching to or unlocking the phone (if the phone is held Portrait-wise). It will then switch back to Portrait. Kind of frustrating.
2) Video on Camera app is dark, very dark. The lighting varies significantly.
3) Edge crashes - if a page is loaded, you leave the app, do something else and switch back, when the page tries to load (previous page) Edge crashes.
vascro
