sudden battery drain!!
sharadh
80
i have a lumia 720 which i bought in feb this year! the battery life has been exceptional since then as i got almost 2 days worth of juice out of the battery! but suddenly it changed! from the last 5 days my battery doesnt even last for one single day even though it is idle for most of the time! the discharge rate shown by various battery apps range from 4% to 7% per hour which increases to 12% when i use whatsapp! i blocked all the background apps and also did a hard reset couple of times but nothing is working out! plz help:(
Hi and welcome to WPCentral. Do you have windows phone 8.0 or 8.1 developer preview on your Lumia 720 ? Also try a soft reset by holding volume down + lock button at the same time until your phone vibrates and reboot itself.
thnx for the reply himanshu...i have wp 8 and like u said...i already did a couple of soft resets and as they didnt help...i did hard resets too...but to no avail! i still have the battery issue...
Marchwind1949
