Here Drive+, battery drain & excessive heat
IMStrugglin
86
So I was taking a trip and using the Here Drive app for directions. The unit was plugged in the entire time and had a full charge when I started. After a couple of hours I get the "battery is critically low" message. The phone was very hot and the charge indicator was on. Has anyone else experienced this with the GPS apps? The charger is a 2.1a so there is no reason a discharge should have occurred. A 1.0a I can maybe see but not a 2.1. This is with a 1020 on WP 8.1.
I have the exact same problem. Mine is even worse that the minute I start using data my phone turns into a hotplate.
Only fix for this is a hard reset. Nothing else will work aside from using the Nokia Software Utility.
bettyaschultz
