NOKIA 930 Problem function double tap wake
Ernane Campos1
11
I have problem with my nokia 930 in the function double tap wake, already realized the standard procedure (reset the phone etc) but instability continues. Please help me?
With only one week of use
What do you mean it's unstable? If you mean it sometimes doesn't work/double tap does not wake the phone, try to double tap the phone a bit slower (it takes some time to get used to) and make sure that the proximity sensor at the top of the phone near the earpiece isn't covered by anything, otherwise glance is disabled (so that double tap doesn't wake your phone in your pocket)
legitloader
