Lumia 520 battery problem after updating to CYAN?.
ashreeram
12
Hi! I have updated my Lumia 520 to cyan a day before. Earlier I used to have developer preview version and it ran fine without any problem. But since cyan update I am noticing a strange problem 1.battery drains tooooooo fast 2. Battery takes too much time to get charged.
Am I the only one with the problem? Or is there any way to fix it?
Don't worry, you're not the only one with battery problems after the 8.1 update. We'll all have to work together to find a fix.
Posted via Windows Phone Central App
Well...good news... I had the same problem and its an easy fix. First off you need to drain your battery to 0% to recalibrate it again when it gets charged. Secondly go to battery saver then turn off background on apps you don't need. And finally..... It will take a day or 2 maximum to see the result. That will be one like and thanks please sir 😉
If it's me you're addressing, switch side method, there you go....one of each.
But I'm afraid I've tried those suggestions....although with the battery thing I didn't let it drop quite as far as 0%.
At one point I had so many things switched off, the phone was a mere ghost of itself. So I've started switching things on again....Location for example. The 8.1 update downloaded some new apps, for which I have no use, Facebook and Skype for example, so I've uninstalled them. Following a Soft Reset earlier, I received notifications that three apps had been awaiting update for a week....though I don't recall ever seeing any number in the Store tile, so those sitting there may have been draining battery....I don't know.
I'm charging at the moment and if I see any improvements I'll post them. I will get this fixed if I can but am not in a great hurry because my 1020 is mainly for photography, but I sympathise with users for whom their phone is their daily driver.
Thank you for your suggestions, which may well work for others☺.
Thanks for the suggestion! I will try discharging to 0%. Lets see if that fix it. Meanwhile I have updated my OS to GDR1. And it brings Cortana alpha to my phone. I am afraid that will drain more battery.
Forgot to mention...unpin Cortana from the menu screen as that's meant to take a lot of battery apparently
There's a couple more for you.
Yes I read in another post that the more tiles on your start screen, the more battery is used. Microsoft do of course say this but you wouldn't think it would matter if the phone is off. The poster said Yes however so my start screen is now getting quite bare.
Edit: The poster later expressed uncertainty of the objective truth of this.
My beloved 1020 seems all right now. I think the trouble in my case was the updates which I was unaware of, and which had been trying to download for a week. Battery stats at the time (using a third-party app) showed the graph descending in a series of many small steps....now the downward slope is smooth. The steps perhaps reflected battery loss from update attempts.
so basically, we can use the phone until I closes, than chart it full? And we will see difference?
Is 30 tiles a lot to drain the battery on start screen? I'm having a serious problem with battery drain as you guys do :(((
That's what I done personally and it really is making a lot more difference. The cyan update really has made my phone last a lot longer. Bear in mind I am not a gamer and haven't been on games today but I last charged it 4 hours ago, been on the net none stop, made a long phone call and done texts and WhatsApp and watched a few YouTube videos and I have 54% left that's moderate usage but its also been on Wi-Fi all day and the videos I watched was HD. I think its really good
I've just replied to the post that you made elsewhere...it was only five minutes ago but I've completely forgotten where😶. No doubt you'll remember. Basically, my judgment was Yes, the more tiles and apps, the higher the battery consumption. But I could be wrong.
Also, some apps are said to be worse than others in that respect.
Edit: Having read other members' posts made since then, the number of tiles may not matter very much, nor the number of apps. However you may have one or more rogue apps that are eating the battery.
Erlpopuaka
