Why are my Phone task causing major drain on my battery?
Ruan Martinelli
"Phone" task causing major drain on battery - L925
Hi guys,
Under Battery Saver, it shows that "Phone" is causing a huge drain on battery.
Here's a screenshot: imgur'dot'com/BP8TuWh.jpg
I have all possible configurations turned off (NFC, bluethooth, no e-mails synced etc).
Also, on this especific screenshot, I have used WhatsApp most of the day and spent only 3:25 minutes on a single phone call.
Please, help! Coundn't find a solution anywhere.
Re: "Phone" task causing major drain on battery - L925
Well, you could just be making a lot of calls. My Phone app went up a significant amount after an extended call one trip.
It could be a momentary hiccup, I encountered a glitch before where most apps looked like they all used insane amounts of power, but it has since gone away.
Are you actually noticing a decrease in battery life?
minale
