Has a fix been found to the 8.1 update chewing through battery power?
WPCentral Question
After updating my L1020 to 8.1 my battery started draining in a matter of hours. I've turned of everything in the background and it continues to drain, and it charges very slowly. Has anyone found a fix to the issue other than reverting back to 8.0?
Re: Has a fix been found to the 8.1 update chewing through battery power
Are you running Cyan?
Sent from my Nokia Lumia 920 via Tapatalk
Power off and back on. If this doesn't fix. Turn off battery saver. If that doesn't work try hard reset.
Marchwind1949
