How do I access my screen/front camera and how do I turn on the flash on the rear camera?
how do i access screen/front camera and how do i turn on flash on rear camera?
camera on screen is visable how do i switch it on. And how do i switch flash on rear camera to get access to the torch app that i have just got?
Re: how do i access screen/front camera and how do i turn on flash on rear camera?
When you have the main camera switched on the main screen you will notice 3 dots, tap on that to access settings and in that you have to tap front camera to get access the front cam.
For the torch if you swipe right from the main screen select your torch app and in that you will find a switch icon to turn flash on and off.
grimmmmm
