Is anyone having a problem with a light leak on the Surface Pro 3?
Surface Pro 3 light leak
I just got my Surface Pro 3 and while i am happy with performance, form factor etc. i noticed that it has big light leaks around the corners. Anyone else having this problem. Light leaks a common problem to the really low quality displays and Surface Pro should have one of the best displays out there. So i guess this one should go back to Microsoft.
Re: Surface Pro 3 light leak
When you say light leak, do you mean "looking at it from the side and I can see light," or "when I'm looking at a black screen, there's light at the edges?" If it's the second, it's largely unavoidable.
bettyaschultz
