My Surface Pro 3 auto screen rotation stopped. How do I make it auto rotate again?
surface pro 3 auto screen rotaion stopped. How to make it auto again?
Suddenly my surface pro 3 stopped screen rotaion auto. and the lock icon of screen rotaion on the right bar with the bright section disappered. Now ı can only change screen way with settings display section but couldnt find how to make it auto again or how to add the auto lock screen rotation button to right bar again. any help? thanks
Re: surface pro 3 auto screen rotaion stopped. How to make it auto again?
IDK if it will help, but if an external display is connected or a type cover is attached (and in typing position), the surface is automatically locked in landscape. So, maybe try disconnecting either or both of those if connected. Probably won't help your situation, just thought I'd throw that out there.
I just started having this same issue this morning. I was looking for the icon in notifications as I went to use the Surface 3 in portrait mode for One Note notes and it would not go to portrait mode, and noticed the icon is not even there. I checked out the troubleshooting page on Microsoft and got to the last option of restoring my Surface, which I do not want to do.
I had this issue just after win 10 upgrade and could fix it ...by pressing the power button and volume up until the typecover backlight blinks. But after some 2 weeks its back again, no screen rotation ... now i'm looking for a permanent solution, made recently an update but still on same state
AlienBro
