My Surface 2 will not charge and now the battery is drained, what do I do?
Denise Wiggins
My surface 2 would not charge and now the battery is drained
I have it plugged in but I am certain that it is not charging. I have had issues with it not charging correctly for about a month now. Microsoft was no help and says I'm out of luck. Is the battery dead and can it be replaced?
Re: My surface 2 would not charge and now the battery is drained
I would recommend you to bring it into one of the stores and ask if they can replace the battery..
Here are a few more tricks to try: Microsoft Surface battery not charging | Battery and power problems
If you're absolutely sure about changing the battery on your own: https://www.ifixit.com/Teardown/Microsoft+Surface+Pro+Teardown/12842
(The tut is for a sp but the sp2 won't be that different)
And lastly: Microsoft Surface Wireless Adapter for Typing Covers | Bluetooth keyboard adapter
Marchwind1949
