When will info leak on the Surface Pro 4?
Surface Pro 4
Any idea when information will start being released on the SPro4? All the rumors so far come from copy/paste sites and untrustworthy. I have the original but skipped out on the 2nd and 3rd one because they weren't enough of a performance boost to justify a purchase. I'm pretty excited about the SPro4, but the only way I'll consider it is if they provide a much better GPU for 3D work and a better quality digitizer with more than 256 levels of pressure. I'm sure the CPU will get a boost since they will probably use a Broadwell chip. I don't need a higher resolution. That just cuts into performance.
Re: Surface Pro 4
If you frequent this site and pay attention to the articles I'm sure the minute anyone knows of credible information you'll find it here.
Assume anything else to be simply rumour.
ayanahmad
