How do I adjust the U.S.A. Denim 1520 Captive key brightness without having to use the battery saver?
u.s.a. denim 1520 captive key brightness
After the us denim release the 1520 captive keys are too bright. How do I adjust them without turning them "off" via batter saver "always on"?
Re: u.s.a. denim 1520 captive key brightness
I haven't noticed a difference at all. In fact I love this new update! I'll look into it for you though and see what I can dig up!
This issue has been tracked to a bug in Device Hub... I had it under Cyan. See this thread for the diagnosis and a workaround. http://forums.windowscentral.com/no...avigation-bar-lights-always-stay-lit-bug.html
I never got around to using the workaround. xandros9 informed me today that an update was pushed to Device Hub to defeat this. My Capacitive Keys are back to normal brightness without me doing anything. Use SysApp Pusher to update your Device Hub.
you can't really adjust them directly - battery saver remains the main way of turning them off.
thanks for the mention RumoredNow! :)
Michael Niehaus
