Is the Nokia Lumia 1520 battery drain faster than 1320?
Jay Lim Jcf
consider to its 2.2 GHz quad-core processor and 1.7 GHz dual-core processor
Is it worth to get Nokia Lumia 1320 in nowadays? or I should get Microsoft Lumia 535?
It's probably not the processor which "drains" the battery "faster" but the higher ppi screen of the 1520.
But in a spec comparison the standby and talk time of a 1520 is higher. (but in these cases the display is not used).
To choose between the 1320 and 535 do a google search "Lumia 535 vs 1320" and check what you want and how much you want to spend.
AquaFusionHydrogenBottle
