W Windows Central Question Mar 6, 2015 #1 The power,camera and volume buttons stop working on my Lumia 900. how to fix everything else works perfectly
AV2RY New member Sep 14, 2013 1,284 0 0 Mar 6, 2015 #2 Re: The power,camera and volume buttons stop working on my Lumia 900. how to fix Try to restart it. If impossible, let the battery die. The plugin the charger and phone will turn on itself.. That will be kind of soft reset Upvote 0 Downvote
xandros9 Active member Nov 12, 2012 16,110 2 38 Mar 6, 2015 #3 maybe a crucial connector went south, I fear service might be what is ultimately needed. Upvote 0 Downvote
Matias Javier New member Aug 22, 2014 3 0 0 Apr 13, 2015 #4 If your Problem persist try rolling back to Windows pone 8.1 Upvote 0 Downvote
