Is there a way to change the auto-save setting on emails when using Edge?
Since "upgrading" to Windows 10 I cannot type 2 lines in an email without the keyboard freezing, the little blue circle showing up and then I have to reset my cursor to continue typing. It is crazy how often this is happening and it is making sending emails unpleasant. Any ideas as to how I can reset the auto-save setting...if there is such a thing...or what else the problem might be. Yes, I am using Edge.
Thanks,
Stefanie
I have an eMachine desktop that I upgraded to Windows 10. My mouse position indicator disappears, and when the clocker circle quits spinning, I have to re-click the mouse pointer to where I was typing for it to reappear. I also see a brief "saving" icon on the Start Menu randomly when typing emails. I have not found any "auto-save frequency settings" to change. Maybe there are two issues? The lost cursor issue is very frustrating.
Thanks.
JakartaMertin
