How can I fix an SD Card problem when booting up my phone?
Problem with sd card when booting
There is an error when i am booting into windows that it says there maybe a problem with the sd and to take it out
Re: Problem with sd card when booting
Welcome to Windows Central.
What device are you referring to? But at any rate, have you tried connecting/inserting your SD Card into a PC and then check if it has corrupt sectors or not? Most SD Card problems are caused by this.
You may create a Windows Central account to respond in this thread.
ankitmalik1909
