Can you Guys/ Gals help me live Fix, Repair, MS Edge-Not working, it wont open?
I have Windows 10,w/ MS Edge I try to click on edge and it just will not open, I get its blue screen for 1-2 sec then desk top.
Please join and provide the following info in this thread:
1) Did you install any updates through Windows Update?
2) How long has it not been working?
I had a similar issue with the calculator app, after one of the cumulative updates it wouldn't open.
However it was fixed later on by another cumulative update...
kesho
