Wireless charging problem since OS build 14393.448, Lumia 950
BobPro2
30
Since OS build 14393.448, wireless charging quit working on my AT&T Lumia 950. Tried replacing the Mozo back plate with the original, no difference. The wife's Lumia 920 still charges fine, so it's not the charging plate. Anybody else having problems?
Update: As stated, wireless charging quit on my L950. I used the Nokia DT-900 charging plate successfully with it for over a year and it still works fine for the Lumina 920. MS tech support said to try a hard reset to fix the problem. Well I did; and it didn't! Next, they said to send the L950 in for repair. Instead, I bought a new wireless charger ($19.99) along with a 2-watt power adapter ($8). That solved the problem.
I have a 950 with that build too after doing WRT cause my phone kept shutting off. I'm gonna stay ok that build instead of the fast ring but I use my wireless charger as well and had it since my 920.
Consanguine
