My surface pro battery charger is not charging
My surface pro charger is not working. I am based in Singapore. I have cleared all posts but it still does not work. Kindly advise
did you buy the device locally? Is there a service centre near you? Perhaps you can try with them to check the cable and charger
Is the device under warranty?
Tech Pulse
