I've noticed a behavior with my Lap Dock, when in a wireless Continuum connection. If I press and hold a key on the Lap Dock keyboard, the result is an output matching that of a single press. For example, if I press the hold the "backspace>" key, only the previous typed character/space is deleted. If I press and hold the "spacebar" key, the cursor advances only one space. If I press and hold any character key, only one character is typed.
If I use the virtual keyboard on the phone during this wireless connection, or if I establish a wired Continuum connection, I do not observe this issue. Pressing and holding a key results in repeated backspaces/spaces/characters as expected.
I am running current released fw/os builds on the X3 and the Lap Dock.
Thoughts?
Thanks in advance!
Thoughts?
Thanks in advance!
