1. Dipesh Shrestha LP's Avatar
    It's been two months that i bought 950xl(single sim variant) and still using it. From my first day of use 950xl gets heat n it's battery 🔋 it's draining so fast. I update my phone to latest os version and even tried hard reset too but the problem is still going on. I haven't install so many apps neither using so many apps in background but still same problem. Microsoft is claiming it's battery 🔋 back up for playing video is 11 hours and music 75 hours in it's site but it's totally fake.
    04-05-2017 01:38 AM
  2. Khandoker Maniruzzaman1's Avatar
    I charge my phone throughout the night (from the time I go to bed till I wake up) and it lasts throughout the day. If I play games, I need additional recharge.
    04-05-2017 05:01 AM
  3. Dipesh Shrestha LP's Avatar
    So it needs to be charge whole night ??
    04-05-2017 07:18 AM
  4. Vishca's Avatar
    Hi
    Check which apps are running in the background, I think by default all the apps run in the background unless you change the settings.
    04-05-2017 08:20 AM
  5. Dipesh Shrestha LP's Avatar
    no i haven't install WhatsApp
    04-05-2017 11:02 PM
  6. pedmar007's Avatar
    Battery life on W10M isn't good. I too have a L950XL and I don't like how quickly it drains as well. Starts at 100% and as I disconnect the charging cable and look at it, it drops to just above 92%. I'm hoping that RS2 fixes that.
    04-06-2017 06:29 PM
  7. Vishca's Avatar
    I did not ask if you installed "what's app", I said check that the apps are not all running in the background. By default every app/programme on your phone is running in the background. Unless you change the settings it can/will drain your battery.
    04-09-2017 09:38 AM
  1. Who is rocking Nokia Lumia 830 along with me
    By sayimanohar in forum Nokia Lumia 830
    Last Post: 04-26-2017, 01:19 PM
  2. How to minimize the pop up while saving a file in Windows 7 .
    Last Post: 04-05-2017, 01:03 AM
  3. Replies: 1
    Last Post: 04-05-2017, 12:48 AM
  4. Replies: 0
    Last Post: 04-04-2017, 11:25 PM
  5. my lumia 530 is not charging batter drains when kept in charging
    By dprateek singh in forum Ask a Question
    Last Post: 04-04-2017, 10:25 PM
