HooToo UE01 Ethernet/USB issues
Does anyone have any experience with the HooToo UE01 Ethernet/USB dongle? I picked one up last week as an alternative to Microsoft's version of that device because the HooToo has 3 USB 3.0 ports as well as Gigabit Ethernet. Well, I can't get the darn thing to work. When I plug it in to my i7/256GB SP3, I get the "connected" tone, then about every 20-25 seconds I get the "disconnected" tone, and it never decided to reconnect, and I get no network connectivity.
I did a little research before buying the HooToo, and all people seem to like it, and I didn't install the drivers from the CD it comes with because all reviewers didn't use it. So I did the same (I let Windows install the driver). Didn't work. So I downloaded drivers from HooToo, and still doesn't work.
Does anyone know how to get this to work? And if possible, maybe some alternatives?
Also, if I bought the Microsoft device, would I be able to connect it to a USB hub, or does it have to be directly connected to the Surface?
Thanks!!!
Thanks!!!
