Hi all,
I'm just checking in to see if anyone has encountered the following:
My relatively new SP4 (lot 1602) has developed a problem where it will occasionally lose the charging connection. The charger light will go off and on, and the screen brightness changes based on battery versus plugged in settings.
Sometimes it will go most of the day and only happen a couple times. Other times it is a constant back and forth.
Yesterday I went to the Microsoft store and replaced the charger, but it turns out the issue wasn't the charger.
Before I go through the hassle of getting the SP4 replaced, I wanted to see if anyone has encountered this and/or knows of a possible fix. This only started within the last week. I've inspected what I can of the charging port and I don't see anything in there that could be blocking the contacts.
Thanks.
Thanks.
