The king is back baby!
Resident Evil 7: Biohazard Review — a series risen from the dead
Fitness Apps
Keep your New Year's fitness resolutions with these great Windows 10 apps!
One Windows
Microsoft is building a new Windows 10 Shell for PC, Mobile and Xbox
Get ready for beta!
Halo Wars 2 Blitz: Game modes, beginner's tips, and more
On the Inside
Everything you need to know about the Xbox Insider Program
Beautiful compromises
Surface Studio review: you'll want one, even if you don't need one
3-in-1
Is this the Surface Phone? Microsoft awarded patents for foldable devices
Windows Central Offers
MCSE Certification bundle is just $39
Even more improvements
All the changes found in Windows 10 build 15007!
Games as a Service
What does the cancellation of Scalebound mean for future Xbox exclusives?
Save $90 on these FRESHeBUDS Pro Magnetic Bluetooth Earbuds
Returning for 2017
We're back with an new episode of #AskDanWindows
Lifetime Subscription
VPNSecure is currently 91% off
Our favorite things
The Best of CES 2017 Awards
Infinity Edge in your hand
The XPS 13 2-in-1 is the Dell convertible we've always wanted
Project Valerie
Razer just made a laptop with three — THREE! — 17-inch 4K displays. 😱
Great design from Palo Alto
HP's CES 2017 releases are truly gorgeous PCs
Intel and Google's big day
CES 2017 Day Two: New laptops, new phones, and old ideas made new
Take five is better than ever
The updated Lenovo ThinkPad X1 packs Kaby Lake chips and zero bloatware
Everything we know about the next Xbox: Project Scorpio
Welcome to the Windows Central Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Page 1 of 2 12 LastLast
Results 1 to 25 of 36
  1. illyc's Avatar
    Member
    Posts
       #1
    what the hell is going on?
  2. Corepc's Avatar
    Member
    Posts
    Global Posts
    1,335 Global Posts
    #2
    Phone will run hot if you use it a lot, espically playing games..
    Battery Drain - check settings->applications->background tasks-> turn off all app that you do need running in background. Also go into apps themselves and turn features off that you do need. Open each and every app that you have.
    Did you recently update to gdr2/amber ? You will most likely need to go through each setting and turn things off that you do not use.
    What are the main apps that you use ?
  3. illyc's Avatar
    Member
    Posts
       #3
    I don't play any games. Only 2 apps have background on - weather and my account. I hit the update about a week or 10 days ago. This issue has only come up the last 3-4 days.
  4. illyc's Avatar
    Member
    Posts
       #4
    did a hard reset to make sure it wasn't a rogue app i'd downloaded...and battery is still draining quickly. i'm talking about 7-9 hours of very minimal use. warranty issue?
  5. jms_209's Avatar
    Member
    Posts
    #5
    Quote Originally Posted by illyc View Post
    I tall depends on what you are doing.
    Playing games drain my battery really bad.
    Streaming video not as bad.
    I had my phone be at 20% after 20 hours of it being on.
    12 hours of sleep mode(unplugged at 93%)
    When I woke up it was 89%,then I used it all day minimal use and was at 20% 8 hours later or so
  6. jagu's Avatar
    Member
    Posts
    #6
    Yup, the same exact issue with me after the GDR2 update! I don't know if its a faulty battery or the update caused something... I have hard reset my phone and also turned off pretty much everything under settings and even if i leave the phone unused the battery drains in like 5 or 6 hours. Before the update, my phone used to last about 2 days of minimal use... Not sure what is going on here. I did notice that after turning OFF data, and just using the phone on WIFI i get pretty decent battery life but still not as good as it used to be before the update.
  7. illyc's Avatar
    Member
    Posts
       #7
    Quote Originally Posted by jms_209 View Post
    absolutely NO games played, NO streaming videos. literally, MINIMAL use and it lasts maybe 7 or 8 hours. completely unacceptable. will contact nokia CS tomorrow.
  8. illyc's Avatar
    Member
    Posts
       #8
    so...Nokia's warranty process requires the consumer to send in via mail their phone for like 2 weeks, so you are without your phone. That makes sense.
  9. gollum18's Avatar
    Member
    Posts
    Global Posts
    1,528 Global Posts
    #9
    That is actually standard across most manufacturers regardless of the os.
    If you ask, they may send you a temporary phone to use while you wait for yours to get back from repair. At least I know Samsung does.
    Sent from the stars...
    xandros9 likes this.
  10. AndrewNZ's Avatar
    Member
    Posts
    #10
    Do you have double tap to wake or glance screen enabled?
    Turn them both OFF and see how it looks then, double tap to wake appears especially power hungry
  11. jms_209's Avatar
    Member
    Posts
    #11
    hmm if it helps RIGHT after I turned on/got mine, I went straight to update.
    I let it update and then downloaded everything else.
    Maybe it could be an app?
    Maybe resetting/restoring your phone will fix it,again just a suggestion.
  12. illyc's Avatar
    Member
    Posts
       #12
    Quote Originally Posted by gollum18 View Post
    I was clearly upset while chatting with CS and she didn't offer anything. I don't get it - what do they expect you to do while your phone is gone? Buy another one?
    Quote Originally Posted by AndrewNZ View Post
    521 doesn't have either, does it?
    A couple days ago I did a hard reset, which didn't solve the issue. Checked for updates while with CS today, phone is up to date. Is there a way to go back to the prior OS version?
  13. SlantNGo's Avatar
    Member
    Posts
    #13
    My battery life improved significantly after upgrading to Amber. Previously I was draining at ~4-5% per hour, and after Amber, it's been down to ~3%.
  14. pdawg17's Avatar
    Member
    Posts
    Global Posts
    185 Global Posts
    #14
    Wow glad I found this thread. My wife's 521 has been draining like crazy since around the time she updated to GDR2 as well. Last night she went to sleep with 69% remaining and 7 hours later it had shut itself off due to the battery being empty! This was on a fresh reboot so no apps were open etc. Also nothing running in the background (had turned it all off to see what would happen).
    I'm pretty upset with Nokia/Microsoft right now as just 2 days ago my 925 blue screened and is now bricked...
  15. illyc's Avatar
    Member
    Posts
       #15
    first of next week i'm sending mine in for service.....we'll see what happens. in the meantime since nokia is taking my phone, i guess i'll go buy another one at walmart and then return it......f'in stupid.
  16. molimelight's Avatar
    Member
    Posts
    #16
    I too am experiencing sudden battery drain after the update. I was trying to find the exact date that the update was pushed but I don't see the date anywhere. In my battery app I can trace the onset to the 27th of August. Prior to the 27th I was draining at 5.5% per hour. Now it's 15 to 20% or more per hour. I've uninstalled any of my more recent apps and have only three things that I allow to operate in the background. Weather Radar Tile, CNN and the Battery APP. I had all three on the phone prior to the update and well before the sudden draining I'm having now. I'm blocking everything else I'm allowed to block. The phone is also warm. I haven't tried a hard reset as I see from above that others have tried it and it didn't change anything.
    1) Does anyone know if there's away to go back to the previous version prior to the update to at least test the possibility if it's related to the update?
    2) Does anyone have any kind of service ticket going on this or made any headway in isolating it to a specific app? I tried to see if I could uninstall Data Sense as that is what I suspected it was, but you can't uninstall it or block it from background tasks.
    Push comes to shove, I'll do what illyc is doing and send it in and buy another one from Wally World and return it if necessary. Too bad WP8 & Nokia don't have "Restore Points." It's a shame because I've really loved the phone and the OS up to this point!
  17. jms_209's Avatar
    Member
    Posts
    #17
    Has anyone actually done a full reset of the phone, as in "when you got it" condition?
    I remember yesterday using some gbc emulator, I had 80% at the time.
    It has know problms of it draining batteries unless you restart the phone.
    I quit it and let my phone sit/do nothing.
    I check 2 hours later 28% -_-
    So I uninstalled gbc emulator,restarted my phone and all was well again.
    I just got 22 hours 3 minutes and still have 38%.
    Also I've been using wifi not cellular.
    Minor web browsing and gaming.
    Doesn't seem to be hardware related,but I'm not too sure on that.
  18. illyc's Avatar
    Member
    Posts
       #18
    I did a "master reset" using the hard keys, but that didn't seem to revert the OS to before the update.
  19. Corepc's Avatar
    Member
    Posts
    Global Posts
    1,335 Global Posts
    #19
    In order to reset to pre gdr2/amber OS. Somebody would need to upload the rom and reflash with ncs. I have the rom but no WiFi to upload it with.
  20. illyc's Avatar
    Member
    Posts
       #20
    welp, phone sent off, bought a new one at WM to be returned within 15 days. let's see what happens.
  21. gaknigge's Avatar
    Member
    Posts
    #21
    this happened to me too. I don't think it is the GDR2 update from Microsoft, but the Amber update from Nokia. I have a Lumia 521. This worked for me.
    • Hard reset
    • Toward the end of the install you are prompted to automatically install system updates. Say no to that. This is in the custom options I believe. Walk through thte post-install steps carefully to find it
    • This prevents the Amber part of the Amber update installing.
    • I installed then from the store the offered HERE apps from Nokia, but none of the others.
    This worked for me. Battery life is back to where it was. I can get two and a half days when I don't do much calling or game playing.
    Best of luck.
  22. #22
    Good to know.
    This is really frustrating though. Started happening to my phone on Thursday (9/5/2013). I used to get two days + of life, now it is going down in 7 hours, and the phone runs warm to the touch (near the camera).
    When you say "towards the end of the install" do you mean towards the end of the hard reset process?
    Also, how do you do a hard reset?
  23. illyc's Avatar
    Member
    Posts
       #23
    Quote Originally Posted by gaknigge View Post
    • Hard reset
    Best of luck.
    hahaa....wish you'd posted this before today! good to know for future reference though, thanks.
  24. molimelight's Avatar
    Member
    Posts
    #24
    • Hard reset
    Best of luck.
    Please let us know if it stays that way over the next few days.. I tried removing a bunch of apps that I rarely used just to see if it changed things. Suddenly it was back to normal, no battery drain other than normal, around 2% per hour. (I wish I knew how to get screen shots to show the graph in my Battery App. It's a pretty dramatic difference in battery use.) I thought I was home free, then two days later it was back and hasn't left since. Draining at 20% per hour! This is getting pretty discouraging. If the reset to pre-Amber works, great. I just wonder if Nokia will track it and fix it. I don't know that there was anything in Amber that was so dramatic that I have to have it. I'm just concerned about future updates.
    Would anyone be interested in a thread that listed all non-Nokia apps on our phones? Maybe there's a common app that is running away on a regular basis.
    Phones are pretty frustrating. There's so much that's locked down on them, it's hard to trouble shoot and find the process that's causing the battery drain. A common element that I am hearing and have experienced with mine is that it's warm. That's tells me something is hammering the processor. There are many of the Nokia apps that you can't keep from running in the background, so it will be up to Nokia to find that and fix it.
  25. gaknigge's Avatar
    Member
    Posts
    #25
    To do a hard reset go to Settings > About Windows Phone. Toward the bottom of that screen is the reset. It will cause you to lose all data so backup first. You can visit the app store afterward to see what you had previously purchased and downloaded. Go slow with that though. In case your phone goes hinky again you can tell what it was.
    Yes, toward the end of the hard reset is the opportunity to choose a custom sestup which in turn leads to the screen where you can choose not to automatically download system updates (read Amber update). In a day or so you will see these udpates in the App store. This is where you have to resist the urge to update everything - because that will just bring back the battery drain.
    Gary
    Quote Originally Posted by Nicholas Tedesco View Post
    Good to know.
  1. [Game] Conquer and Trade on the Moon (512 MB WP 7.5 and 8)
    By Kari Rauta in forum App Spotlight
    Last Post: 06-23-2016, 01:31 PM
  2. Windows 8 Driver problem? Win8 won't recognize my phone
    By briankiser in forum Nokia Lumia 920
    Last Post: 02-27-2014, 10:31 AM
  3. Amber bricked my phone
    By Carbon Based Lifeform in forum Nokia Lumia 920
    Last Post: 08-22-2013, 05:09 PM
  4. Wow Celebrity Guess - Game for Windows Phone 8
    By minqidev in forum App Spotlight
    Last Post: 08-21-2013, 06:34 PM
  5. Windows phone is the second most used OS in Latin America
    By agmanuel in forum Windows Phone 8
    Last Post: 08-21-2013, 04:28 PM
Posting Permissions
