Hi, i was reading the thread about Lumia620 bad battery backup but to be honest the battery life has been good for me with moderate usage for a 1300mAh battery. I tried to test it by fully charging it then let it drain till 1% or so.. It gave me about 23hours but the problem i face with battery percentage is that the phone switches off afterr going down from 4% or so.. I use the "Battery" app for percentage which has a red icon and has good ratings on App Store and it also tells right battery percentage compared to the one in settings and both show the same. but ive noticed it two times that phone switches off below 4% (dont know accurate what % below 4). But atleast doesnt last till 1% as fas as i know. I switched from Android and it did't had as such issues. So is it normal with Windows Phones or something is wrong with mine?
Thanks
Thanks
