L620 with L520 Battery (by Mugen Power)
Checki
Banned
Apr 17, 2013
200
Hi guys!
I just got my L520 battery from Mugen Power for my L620.
They said, it doesnt harm the phone, and it "should" fit.
I say: It DOES fit.
Just remove that plastic rubber stuff from the back of your backcover, so the battery got more space. Then it fits <quite> perfect. I can press all buttons like before, nothing changed.
Now i have 1600mAh instead of 1300mAh, which should give me more power to survive a long hard working day :)
Oh, and if you wonder "whats that cover", its the Lumia 620 protectice shell cc-3061. Which is also very good...
Some pictures. Have fun
[HLI-BL5JSL] Buy Mugen Power 1600mAh Extended Battery for Nokia Lumia 520 / T-Mobile Lumia 521 / 5800 XpressMusic / N900 / X6 / C3
WP_20131005_004.jpgWP_20131005_005.jpgWP_20131005_006.jpgWP_20131005_008.jpgWP_20131005_009.jpgWP_20131005_011.jpgWP_20131005_012.jpg
Is that OK to remove that plastic? Since I've got my L620 yesterday I thought that hardpaper/plastic stuff was GPS/Bluetooth/NFC related.
Isn't the plastic back cover thing for nfc ?
Sent from my RM-846_im_233 using Tapatalk
There is nothing to agree. Touch it, its SOFT!
And when i say its paper, it is paper. Picture coming soon for you guys
Nice!
I guess they added this soft paper to hold the battery, cause the battery is smaller than the place
I guess I gonna order such one aswell, if their L620 Mugen XL is too big to use the normal backcover
Normally they have a normal size one (here with +8%) and if there is another one its bigger with bigger cover. So this one is a good compromise
I asked on twitter if it would fit the 620 and they said no. The lying bastards...
I sent email to them to ask if the Mugen 520 would fit, they said no problem, same size.
I wonder when they come with the XL for the L620 and the capacity of it...
I wouldn't buy this unless I see an user review... I don't think it really is 24300mAh.
Even if it's 1600mAh the
Mugen is over $40.
You local Batteries + can test and find out exactly what it's rated at ( for free) I've done that on a few ''high capacity'' Li-ion batteries
some have proven correct some not, with the ones that didn't match the stated specs, (they were a bit more than OE) after informing
the eBay seller they refunded me 25 % So two batteries and a stand alone charger cost me $12.75 instead of $16.98
That 2400 is crap, i read a few reviews. But, try it yourself. Mugen power is quality. Cheap is not always the beat way to go. But: your decision
longinotti101
