1. dinesh_altius's Avatar
    Hello guys,
    I've this problem, while making or receiving calls in my lumia 820 the person on the other side cannot hear me. It's been bothering me for a long time. Only when I remove my phone from ears and take it near my mouth or use the earphones, the person on the other can hear me. I tried different ways to hold my phone while on a call but they all have yielded nothing. Any of the 820 owners experienced the same problem and have overcome it ?
    Please help me out here, I can't have my earphone with me every time when I'm on call.
    Many thanks.
    08-18-2013 02:13 AM
  2. Laura Knotek's Avatar
    Hello guys,
    Many thanks.
    That does not seem normal. Do you have a Nokia Care Center in your area? I would suggest taking the device in for exchange or repair.
    08-18-2013 02:17 AM
  3. akks's Avatar
    Yeah i too experience the same problem since i bought this phone 3months back. Its a kinda manufacturing defect i suppose.
    Didn't get time to contact nokia care yet.
    Everyone on the other side tell that they can't hear me.. No such problem with earphone.
    08-18-2013 04:43 AM
  4. akks's Avatar
    The problem is exactly like what you've described..
    Lets wait for the amber update. If it issnt getting corrected by amber update, hardware needs to be checked from NCC
    08-18-2013 04:45 AM
  5. Rodrigo Mendes's Avatar
    Do you use any screen protector?
    08-19-2013 11:02 AM
  6. akks's Avatar
    yeah. How will that interfere in the call quality?
    The mic holes ain't covered.
    08-19-2013 11:21 AM
  7. coolsidx's Avatar
    same problem here !!
    surely some prob with device
    08-19-2013 01:21 PM
  8. akks's Avatar
    Any help after the amber update?
    08-20-2013 01:02 AM
  9. Rodrigo Mendes's Avatar
    This is a not software problem.
    If I were you, I would try to remove the screen protector. I have heard many similar complaints and all were related to that. Even that does not cover the microphone.
    08-20-2013 06:27 AM
  10. akks's Avatar
    Oh, ive put a new matte screenguard only recently.. Don't feel like removing it now.. So for the time being i gotta adjust with the poor call quality 😞
    Btw im downloading amber now.. Lemme see if it helps in any way..Will let u guys know after tthe update ..
    08-20-2013 06:49 AM
  11. dinesh_altius's Avatar
    I've no screen guard and protective back case. I'm using the mobile as I received from the box. Heard this is a widely reported issue. How can Nokia be blind on this?
    08-20-2013 10:19 AM
  12. budney's Avatar
    I had this issue with my AT&T 820. I flashed the last update (not Amber) instead of doing it OTA got rid of the problem for me. Before the update I went as far as sending it to Nokia, but it didn't help. Also you may want to make sure any cases or protective coverings give plenty of room to both mics. My first case covered up both to a point of making the issue worse.
    Sent from my Lumia 720 using Tapatalk
    08-20-2013 11:06 AM
  13. akks's Avatar
    Updated my L820 to Amber today.. Did a few calls after that.. Noone complained that they cant hear me..(Earlier almost everyone used to complain so) Has the update solved my problem or issit a placebo.. Gotta wait and confirm.
    08-20-2013 11:48 AM
  14. Rodrigo Mendes's Avatar
    akks, I read again what you wrote at first place and realized I was misunderstanding your problem.
    I almost made ​​you miss a screen protection for nothing.. Sorry for that!
    08-20-2013 11:57 AM
  15. akks's Avatar
    Its ok.. I still was wondering wat screen guard has to do with the mic! 😉
    08-20-2013 01:21 PM
  16. shoodav's Avatar
    I have same problem with 6 month old nokia 520. Have been told in Vodafone shop that the internal speakers have blown. Currently phone away for repair.
    02-10-2014 08:09 AM
  1. Replies: 27
    Last Post: 08-16-2015, 07:49 PM
  2. Problems with Viber contacts
    By croivo in forum Windows Phone Apps
    Last Post: 03-15-2014, 08:41 PM
  3. Low call alert volume
    By don44 in forum Huawei Ascend W1
    Last Post: 08-22-2013, 06:44 AM
  4. Apps space problem
    By teo155 in forum Windows Phone 8
    Last Post: 08-17-2013, 07:40 PM
  5. Problem....Please Help!!!! ----Nokia Lumia 520
    By Abhijit88 in forum Nokia Lumia 520
    Last Post: 08-17-2013, 03:17 PM
