We made some changes
Our new forums are here!
Saving money on data
Mint SIM is the perfect way to get cheap data in the U.S.
Don't count Windows Phone out just yet
Dead? Psh. Here are 5 reasons to stick with Windows 10 Mobile
VPN vs. Proxy
The difference between a proxy and a VPN
Latitude attitude
Dell Latitude 7280 is a business laptop with tons of consumer attitude
4K all the way
You probably don't NEED a 4K webcam, but we love Logitech's BRIO 4K anyway
Long live Windows phone
Contrary to popular belief, Windows phone won't die anytime soon
XP-YESSSSSSS
Dell's already awesome XPS 15 gets even better in 2017
Surface Pwn 5
Surface Pro 5, Project NEON details leaked on LinkedIn?
Redefining the PC
Why Microsoft's Surface phone could be MUCH more than a mere 'phone'
Surface table meets Windows 10
Yes, we did put Windows 10 on the original Surface table ... and it rocks
Cream o' the crop
Before buying a Microsoft laptop, check out our pick for the absolute best
Simple and secure, just the way I like it
We think Windows 10 Cloud is a great idea, here's why
uber micro
Halo Wars 2 has something for everyone. Here's our full review.
Oldie but goldie
We reviewed Microsoft's decade-old Surface table
Creators Update comin' at ya
These are the coolest new features in the next big Xbox One update (video)
Buyer's guide
The Razer Blade 14 is the best laptop Razer has to offer
Windows 10 app gems
10 terrific Windows 10 apps you should be using
Tower of power
Here's what we think of Dell's XPS Tower Special Edition
Quite a deal
Grab the complete C# coding bootcamp for $41!
Welcome to the Windows Central Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 14 of 14
  1. PhilS_UK's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #1
    Hi,
    Is the general consensus that a factory reset on a new phone helps battery life? Or can that now be dismissed?
    Also was this advice for branded/newtork locked handsets only or did it apply to unlocked models also?
    Phone due tomorrow :)
    Thanks
  2. paulm187's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #2
    Not conclusive but doesn't hurt to do it before you setup the phone.
  3. luckylifo's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #3
    I remember reading a bunch threads about people bricking the 920 after factory reset. Has that been fixed?
  4. rdifiori's Avatar
    Member
    Posts
    Global Posts
    383 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #4
    Be careful. Resetting can brick some 920s.
    Sent from my RM-820_nam_att_100 using Board Express
  5. NokFromApp's Avatar
    Member
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #5
    I am on my third 920. The first one I had had really bad battery life, so I hard reset it and I definitely saw a remarkable improvement. I had to change it for a power button problem. So the second one I had, I did a hard reset before I set it up...same with the third one. Steps I take, and has never failed me, are to charge the phone to 100% and then hard reset it while the phone is still on the charger.
  6. jmseamonkey's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #6
    Quote Originally Posted by NokFromApp View Post
    Out of curiosity, what kind of battery life were you initially getting on your first 920, and now what are you getting on the second/third devices?
  7. NokFromApp's Avatar
    Member
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #7
    Quote Originally Posted by jmseamonkey View Post
    I was barely getting through 8-10 hours before the reset and then went up to 24 hours soon after that. Note that I did not return the first or the second device because of battery problems. Once I saw the improvement on the first device after the reset, I did the same with the second device and third one before I started to actively use the device.
  8. Jake52's Avatar
    Member
    Posts
    Global Posts
    91 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #8
    I'm on my second phone, the first one had bad battery drain in standby. The second one is fine when the phone is in standby but whenever I use it the phone gets somewhat hot and battery drains pretty fast. I've had it for a week and I just did the factory rest about 10 minutes ago. Everything went fine and it reset without any problems. I'm going to keep an eye on the battery life and if I'm still having issues while using it then I'll go exchange it for my third. I guess it's a crap shoot if the factory reset will brick your phone.
  9. michail71's Avatar
    Member
    Posts
    Global Posts
    1,844 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #9
    I'm not convinced the reset really does much of anything. We do have many users, myself including, that have reported dramatically improved battery after a week or two of use. I never did a reset on mine.
  10. death_eater's Avatar
    Member
    Posts
    Global Posts
    35 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #10
    I was planning to do the hard re-set tonight due battery problems since day 1 (now is day 8). But since you said it, okay maybe I will give another week if my battery improves. Right now I charge my phone almost 3 times in 2 days.
    If this continues then I will do the hard re-set and just hope it won't bricked.
  11. Blkacesvf41's Avatar
    Member
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #11
    Let me start by saying that if don't have a 920. With my 822 I'm getting very good battery life. I'd suggest to you guys that you look into some of your settings to try to resolve this issue. For instance, under the cellular settings mine came defaulted to global and I set it to cdma/lte. Why have those extra radios running and draining juice. Also look at the apps you've installed. I've heard of some such as Skype, draining your battery.
  12. socialcarpet's Avatar
    Banned
    Posts
    Global Posts
    1,966 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #12
    It makes absolutely no sense to me whatsoever why this would help battery life, unless it's uninstalling software that the user installed which was running in the background and using a lot of battery.
  13. devize's Avatar
    Member
    Posts
    Global Posts
    242 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #13
    Quote Originally Posted by socialcarpet View Post
    I agree. I was going to do this when I first got my phone but I couldn't be bothered and didn't want to risk bricking it for something I can't see really doing anything.
  14. PhilS_UK's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #14
    Well after receiving my 'Unlocked/unbranded' 920 yesterday and one full charge (without doing a reset) I am about 22 hrs in with 20% battery remaining.
    Naturally this includes a fair amount of use, installing, updating, playing with camera, few calls etc... so seems pretty good so far! :)
  1. Replies: 9
    Last Post: 11-20-2012, 06:42 PM
  2. Possible credence to the reset theory for battery life
    By fiftiesdean in forum Nokia Lumia 920
    Last Post: 11-16-2012, 09:47 AM
  3. Help with factory reset
    By mdelacoma in forum Samsung Focus
    Last Post: 06-18-2012, 11:57 PM
  4. Want to buy the Cyan 900 (Need Help)
    By rgrdovic in forum Nokia Lumia 900
    Last Post: 04-11-2012, 09:59 PM
  5. Is it possible to factory reset your phone?
    By podsnap in forum Windows Phone 7
    Last Post: 10-07-2011, 04:14 AM
Posting Permissions
