Just an FYI.
I had NO problems with battery life or heat.
The other night I installed a bunch of apps. Suddenly the next day my phone is getting warm in my pocket and the battery is draining like mad. Literally, like down to 70% in 1 hour without doing ANYTHING on the phone.
Started uninstalling apps. (I wish I had kept a list of what i had on there, sorry. If there is a way I can see apps I had installed in the past, let me know what it is and I will post a list of the probably offenders here)
I can tell you one was comprehensive health app that tracked weight, exercise, diet etc. The others were task minder, to do list apps, some games and the battery monitor app.
Anyway, one or more of the health apps or to do list/task apps was clearly running buck wild in a background process, one that could not be disabled.
I kept the games, none of them were causing the problem.
It's crystal clear to me that this is the issue, because I NEVER had the problem before and as soon as I uninstalled those apps and rebooted the phone, the temperature went back to normal and my battery life became awesome again.
If your phone is running hot and/or your battery life is crap, uninstall all your third party apps in groups of 2 or 3 and reboot each time and test battery and temps. I would be very surprised if this does not solve your problem.
