We made some changes
Our new forums are here!
Saving money on data
Mint SIM is the perfect way to get cheap data in the U.S.
Don't count Windows Phone out just yet
Dead? Psh. Here are 5 reasons to stick with Windows 10 Mobile
VPN vs. Proxy
The difference between a proxy and a VPN
Latitude attitude
Dell Latitude 7280 is a business laptop with tons of consumer attitude
4K all the way
You probably don't NEED a 4K webcam, but we love Logitech's BRIO 4K anyway
Long live Windows phone
Contrary to popular belief, Windows phone won't die anytime soon
XP-YESSSSSSS
Dell's already awesome XPS 15 gets even better in 2017
Surface Pwn 5
Surface Pro 5, Project NEON details leaked on LinkedIn?
Redefining the PC
Why Microsoft's Surface phone could be MUCH more than a mere 'phone'
Surface table meets Windows 10
Yes, we did put Windows 10 on the original Surface table ... and it rocks
Cream o' the crop
Before buying a Microsoft laptop, check out our pick for the absolute best
Simple and secure, just the way I like it
We think Windows 10 Cloud is a great idea, here's why
uber micro
Halo Wars 2 has something for everyone. Here's our full review.
Oldie but goldie
We reviewed Microsoft's decade-old Surface table
Creators Update comin' at ya
These are the coolest new features in the next big Xbox One update (video)
Buyer's guide
The Razer Blade 14 is the best laptop Razer has to offer
Windows 10 app gems
10 terrific Windows 10 apps you should be using
Tower of power
Here's what we think of Dell's XPS Tower Special Edition
Quite a deal
Grab the complete C# coding bootcamp for $41!
Welcome to the Windows Central Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 15 of 15
  1. LordGreylock's Avatar
    Member
    Posts
    Global Posts
    197 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #1
    Ok, so I've had my Lumia 920 since about release date. It's been working great, with very few issues. The battery has been doing very well for me and I generally love the phone.
    Now on to my problem. I am posting this to see if anyone else is having similar issues.
    I used the 920's navigation many times so far and I encountered an issue.
    While using the Navigon app to reach my destination about an hour away, I noticed that when I got there my phone was almost dead, yet I had been charging the phone the whole time, so assuming it was my car power adapter I decided to do some testing at home using USB in a little more controlled environment.
    I have used the Nokia Drive and Navigon apps for this test.
    With the Navigon app I set a destination and let Navigon route to the destination in demo mode while plugged into USB on my computer, the battery discharges faster than it can recharge and the phone gets extremel hot. Thinking maybe it was just the navigon app, I decided to try the same thing with the Nokia Drive app.
    I started the Nokia Drive app and set a destination, although it can't demo the route I let it sit there in the navigation mode. The phone was warm, but not hot this time. The phone gained little to no battery charge, leaving me to believe that in some circumstances the battery could also drain faster than it would charge even using Nokia Drive.
    For me this is a huge problem because I typically use my cell phone for GPS since it's a very convenient solution. I also typically drive long distances for work, in which case my 920's battery would die before even reaching my destination.
    Again, my battery seems to be fine on a normal day to day basis, the issue seems to be when I'm trying to use GPS. Has anyone else extensively used the GPS on this phone and run into similar issues?
  2. palandri's Avatar
    Retired Moderator
    Posts
    Global Posts
    9,915 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #2
    This has been posted a couple of times. The solution was to either get a charging only USB cable or making a charging only USB cable by shorting the data wires in the cable. Not using a charging only USB cable would only allow 500mA of power which isn't enough when running the navigation application.
    LordGreylock likes this.
  3. wamsille's Avatar
    Banned
    Posts
    Global Posts
    693 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #3
    You need to make sure the cables you are using are charging only and if you are using a CLA in the car, make sure it has a high enough amp rating to charge the device while it is being used. Many phones today draw more power than older cables can pull into the device to keep a charge. FYI, I wouldn't skimp on anything that had to do with maintaining the battery / charge of a device.
  4. LordGreylock's Avatar
    Member
    Posts
    Global Posts
    197 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #4
    Ah, ok. I'll check out the cables then, I thought maybe it was something else. I didn't see the other posts about this.
    Thanks
  5. wamsille's Avatar
    Banned
    Posts
    Global Posts
    693 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #5
    Quote Originally Posted by MisterMhz View Post
    Thanks
    Considering every day there is some new thread about how terrible the Lumia 920 is and that it is a travesty of justice that this was released with beta software on it instead of a fully functioning Windows Phone 8, I’m not surprised you couldn’t find a thread on battery usage and discharge that isn’t a strongly worded letter of regret and misfortune.
  6. LordGreylock's Avatar
    Member
    Posts
    Global Posts
    197 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #6
    Quote Originally Posted by wamsille View Post
    I hear ya. I usually search before posting too. I just thought maybe I had a legitimate problem or I was doing something wrong, I even went out and got a new usb adapter for my car thinking that was the issue. Never thought it was the cable itself.
  7. Vishal Prakash's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #7
    MisterMhz, please let us know if using a "charging only" cable helped you. For me this issue is big enough to return the phone.
    thanks.
  8. Etyrnus's Avatar
    Member
    Posts
    Global Posts
    689 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #8
    The charger I have in my car does well at charging the 920 while using Navigon actually. It was just the generic 2 slot USB charger from Walmart.
    Also, if you are using an older car charger, even a dedicated one, it may not have the amperage to charge the 920 properly.
  9. Vishal Prakash's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #9
    Today I used navigation for around 30 mins drive with the 920 charging + nokia drive with downloaded map and mobile data turned off. The battery was 48% remaining and after the drive it was still at 48% remaining. The charger is Capdase Picoplus. It is a 5V, 2.1 A charger .
  10. Kins69's Avatar
    Member
    Posts
    Global Posts
    65 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #10
    Hello, I am new to this board though I have been following it since I got my 920 in November 2012.
    I have the same issue in the car while using Nokia Drive. Despite using a 2.1A charger, the battery is drained even after a short drive.
    My Lumia 800 does not suffer from this on the same charger.
    I also tried several chargers, which did not help.
    I do not know what you mean above by a "charge only cable". What else could a Duracell cigarette lighter plug be?
    Even the tech guy at the Nokia flagship store in Helsinki was not able to help, and if I don't find a charger soon that will actually charge my phone, I'll have to get rid of it (this + all the other known issues on this phone have made it quite insufferable since almost half a year). :(
  11. realwarder's Avatar
    Posts
    Global Posts
    3,446 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #11
    Quote Originally Posted by Kins69 View Post
    The USB charger must 'tell' the phone how capable it is at providing a charge current. The charger does this via the data pins on the cable. There are around 10 different ways this is done (typically different voltages on the pins) which makes it kind of stupid because we all look at a charger and think it will just work. There are also standard ways to do this (USB BCS1.2) but that came later than some phones and so the world got into a mess.
    Typically an iPad 2.1A charger will not fully work at 2.1A with many phones (other than Apple) and instead the phones will play safe and only charge at the slower 0.5A (500mA) rate. Which makes them look like they work but it's working in a limited manner. Of course iPad chargers are the easiest to find...
    Android tablet chargers often short the data pins which is more standard - so if choosing a charger for your phone, an Android charger will be much more likely to run at the full rating.
    Of course if Nokia also sell one, that will work too.
  12. sideden's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #12
    I have the same problem here. Well, not that similar but I think mine is worst. Last couple of days I cannot charge the 920 even if I charge it at home. I have to restart the phone (while the charger is plugged in), then it will charge normaly. Same thing have to be done when I want to recharge the 920 in my car. Any idea why?
  13. realwarder's Avatar
    Posts
    Global Posts
    3,446 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #13
    Quote Originally Posted by sideden View Post
    Makes no logical sense to me. Contact Nokia Care.
  14. pr0phecy's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #14
    Yep, having the exact same issue here. Lumia 920 with Navigon. I use an Arctic 2.1A car charger and it charges my phone superbly when I don't use Navigon! But when I start to use Navigon, the battery starts to discharge! So in my case I don't think it's the cable at all, nor my car charger. So I still don't know what the cause of this is. Is it a phone issue? Or is it a Navigon issue? Strange thing is that it has worked in the past but probably after some update (Nokia or Navigon, you tell me) the battery drain issue started to raise it's ugly head. Anybody else here where the charging did indeed work in the past, like my case? Or did you have the issue on day one? Thanks!
  15. Talderon's Avatar
    Developer
    Posts
    Global Posts
    1,009 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #15
    I bought a spare Kindle Fire HD cable as it is charge only and can handle 5a and also several feet long. I then bought a 1000w inverter that just plugs into the charge port that has 1 USB (5a) and one household plug. I have my Laptop mounted on a holder and my phone holder on there as well. I plug the phone into USB and laptop into the plug and never have an issue with charge when using GPS.
    I know the phone does not pull the full 5a, but with this setup, having 5a available, it can pull all it wants. :)
  1. 2 week old Nokia 822 plus wireless charging plate and battery cover
    By madisonjar in forum Marketplace Archive
    Last Post: 12-05-2012, 12:45 PM
  2. Replies: 0
    Last Post: 11-21-2012, 02:22 PM
  3. Battery Power and Mobile Charging Questions
    By MEDaugherty in forum Nokia Lumia 920
    Last Post: 09-07-2012, 12:58 PM
  4. Battery Charging Issue
    By lola.bee in forum Nokia Lumia 710
    Last Post: 07-25-2012, 02:59 AM
Posting Permissions
