1. leeds_fan's Avatar
    HELP. Hi, Took a picture in a dark room with my 920,first I turned the flash off then I pressed the camera button halfway down to focus then pressed it fully down,the picture was pitch black,three too four seconds later the phone's screen flashed a bright white light, any ideas how to fix this or is my phone faulty or am I doing something wrong. Thank's
    12-16-2012 09:13 AM
  2. congusano's Avatar
    That is normal. Unexplainable as to why that white flash happens, but it seems to happen with many other of our phones (mine included). I wouldn't worry about it, as it does not mean you have a defective phone.
    leeds_fan likes this.
    12-16-2012 09:47 AM
  3. CoZmicShReddeR's Avatar
    Depends on how dark the room is... If your talking about a bedroom with no lights and the curtains closed then it would be normal for it to show up as nothing... Cameras need natural or artificial light... Back lite cameras use a censor to brighten the image in low light but even those images can get really grainy if the lighting is next to none...
    12-16-2012 10:01 AM
  4. 2DrO4's Avatar
    If you want to turn off all lighting from the phone completely, don't forget to turn off Focus Assist (and your flash).
    12-16-2012 10:09 AM
  5. leeds_fan's Avatar
    There is some natural light,but the photo's come out just like any other photo with no flash.
    12-16-2012 11:19 AM
  1. Replies: 10
    Last Post: 01-31-2013, 06:06 AM
  2. Replies: 39
    Last Post: 10-31-2012, 09:27 PM
  3. Major Camera Problems
    By RiseAgainst94 in forum Nokia Lumia 900
    Last Post: 04-30-2012, 02:24 PM
  4. Nokia Lumia 800 Low Light Sample Pics
    By TheWeeBear in forum Nokia Lumia 800
    Last Post: 11-03-2011, 08:32 PM
  5. Strange camera problem
    By davekr#WP in forum Samsung Focus
    Last Post: 04-19-2011, 02:52 PM
