Hello! I have a very apparent battery problem. I didn't notice it at first but after about 4 days, I know it hasn't gotten better. My 920 is international, running on T-Mobile's network (no data). I've done almost everything I can think of:
Bluetooth off
NFC off
Data off (highest set to 2G, though. Should I change that?)
WiFi on
Location off
Sensitivity set to normal
Brightness low
Connect to xBox Live/music off
Autoupload to Skydrive off
All apps blocked from running in the background
I don't think it's any apps causing the drain, because my battery drains constantly no matter what I'm doing. Browsing the WPCentral app causes the battery to drop 1% every 10 minutes or so. I haven't tested the idle drain but I know that with light usage the battery drains more quickly than it should.
I think my CPU has a problem. It's always warm no matter what I'm doing. It never gets too hot to touch but it's always warm. Is this something Nokia can fix through an update? And if not, do you think Nokia will replace it? I'm doubting they will replace it, since I'm in the US and I have an international 920 but I will try emailing them. I'm also considering flashing Portico to my phone, seeing if that will help. But my product code isn't available yet. Does anyone have any suggestions? Or is my battery Just a dud? Thanks.
Bluetooth off
NFC off
WiFi on
Location off
Brightness low
