So my wife started having really bad battery life a few days back. Not sure whether related to her wireless charger, but the issues seemed to start after she got it. I'll try some of the suggestions here. FWIW, here are the series of textsI got today after she took it off the charger at 100% this morning at 6:15 am.
8:22 - Did about 5 minutes of facebook and a text to you - down to 83%
9:01 - 76%
10:15 - 59%
3:09 - 15%
3:56 - 4%...I only have 20 mins left [battery saver msg I presume]. Barely used today.
I sure hope these suggestions work (the soft reset most importantly), because wifi/bt/nfc are off and Nokia Drive is disabled.
Portico on AT&T.
Wow, that's much worse than what I was experiencing. Definitely try the soft reset, an maybe even try to avoid the wireless charger for a while. I also uninstalled Nokia Drive even though I had it blocked. I'm not sure if that had any impact on my battery life, though. I doubt it, but I'm not really going to use that app (though it is pretty nice!) so it's taking up space for nothing
