1. xenoglyph's Avatar
    So I saw some people recommending a wipe to fix battery drain. Thought it sounded stupid so I ignored them. Noticed the Chinese 920 firmware on NaviFirm, completely different phone model, I thought hey, let's try something stupid and see what happens if I try to flash it
    Whaddya know, it flashes about 1% of the ROM and fails because it doesn't like the bootloader. Now phone is effectively bricked, stuck in (red screen) flash mode. So to cut this short I went back and flashed a fresh copy of Portico to fix it. Lo and behold, the phantom battery drain is gone, even with my same apps (not much), and same settings. I like my phone again.
    I don't know if a factory reset will have the same effect, all I can say is my phone is back to it's old self after flashing the Portico ROM via Product Support.
    01-03-2013 09:24 PM
  2. jdhooghe's Avatar
    How much was it draining?
    01-03-2013 11:40 PM
  3. xenoglyph's Avatar
    It was draining 50-75% overnight (6-8 hours), at idle. No email checks, no wifi, etc.
    01-05-2013 10:17 AM
  1. Update on battery drain issue with Portico
    By xenoglyph in forum Nokia Lumia 920
    Last Post: 12-23-2012, 04:40 AM
  2. Phone Lockup and Heat/Battery Drain - Tips If You Have This
    By sandmanfvr in forum HTC Arrive / 7 Pro
    Last Post: 06-24-2011, 04:42 AM
  3. Battery Drain
    By cdook in forum Samsung Focus
    Last Post: 04-10-2011, 06:49 AM
