Latitude attitude
Dell Latitude 7280 is a business laptop with tons of consumer attitude
4K all the way
You probably don't NEED a 4K webcam, but we love Logitech's BRIO 4K anyway
Long live Windows phone
Contrary to popular belief, Windows phone won't die anytime soon
XP-YESSSSSSS
Dell's already awesome XPS 15 gets even better in 2017
Surface Pwn 5
Surface Pro 5, Project NEON details leaked on LinkedIn?
Redefining the PC
Why Microsoft's Surface phone could be MUCH more than a mere 'phone'
Surface table meets Windows 10
Yes, we did put Windows 10 on the original Surface table ... and it rocks
Cream o' the crop
Before buying a Microsoft laptop, check out our pick for the absolute best
Simple and secure, just the way I like it
We think Windows 10 Cloud is a great idea, here's why
uber micro
Halo Wars 2 has something for everyone. Here's our full review.
Oldie but goldie
We reviewed Microsoft's decade-old Surface table
Creators Update comin' at ya
These are the coolest new features in the next big Xbox One update (video)
Buyer's guide
The Razer Blade 14 is the best laptop Razer has to offer
Windows 10 app gems
10 terrific Windows 10 apps you should be using
Tower of power
Here's what we think of Dell's XPS Tower Special Edition
Quite a deal
Grab the complete C# coding bootcamp for $41!
Your go-to laptop guide
Introducing our ultimate laptop buyer's guide
Listen here
Attn Android and iPhone users: What you need to know about Windows phone
Old is new?
The original Surface Pro still holds its own in the 2-in-1 world
Xbox Greenlight?
No, internet, Microsoft isn't opening Xbox to all UWP games
Welcome to the Windows Central Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree7Likes
  1. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #1
    I have overall excellent experience with my white 920.
    The battery life was not great in the first few days and then it started to sustain longer and longer until last week. I could feel that the phone got hot and the battery drained very quickly. I made sure that I turned off all apps and closed down all connections (blue tooth, wifi, nfc and etc) but it did not help. Sometimes it could last two days and others, only a few hours.
    I eventually found the cause, of my phone at least. It was the "Internet Explorer". If I browsed a web page with auto refresh function, for example, AAPL: Summary for Apple Inc.- Yahoo! Finance, even I closed it using the back button, it still functions in the background and the constant refreshing drains the battery. A power-off-and-on would not solve the problem since after the phone restarts, it remembers the last active webpage and it will keep refreshing and draining the battery. What was the solution? To close a web page properly, you close the tab first and use the back button. This has solved my problem perfectly. As long as I close all the tabs before exiting internet explorer, the battery always works fine. I can also replicate the draining problem by leaving one of those page on.
    So far, I had all the four famous problems and three have partially been solved including the battery one. I had the black screen during a call. A blow on the proximity sensor solved it. I had dust piled up on the front camera. Blowing air throw the earphone with a compressed air can solved it mostly. I then used a small piece of tape to cover the earphone outlet and it seemed to work fine so far (I seldom use an earphone). The only remaining problem is that the brightness does not work perfectly. It is not a big deal compared to the other three. So overall I am happy.
  2. zack251's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #2
    I also found when phone getting hot it drained the battery. It also means that an app is not closed properly. The other day I installed and ran Skype. I closed the app by pressing the back button as usual but somehow Skype still ran in the background and the phone got really hot. I battery was down 40pc in an hour! I removed the Skype and battery is back to normal.
  3. Yev91's Avatar
    Member
    Posts
    Global Posts
    74 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #3
    I get huge drains with Baconit when in class, I guess its a sign...
  4. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #4
    So both IE and Skype could be running in the background without you knowing it.
  5. denzilla's Avatar
    Member
    Posts
    Global Posts
    354 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #5
    Internet Explorer might be what draining your battery, but its pretty much random for everyone. Just yesterday I went to take a leak @ 9:35am and my 920 battery drained like **** till I restarted the phone. I usually don't urinate @ 9:35am so I figured that was the root cause....
  6. LazySunday's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #6
    Quote Originally Posted by denzilla View Post
    LOL's
  7. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #7
    That could be easily fixed: plug the charger in when you take a leak next time.
  8. conanheath's Avatar
    Member
    Posts
    Global Posts
    589 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #8
    Quote Originally Posted by zack251 View Post
    So I guess Skype is still a problem? MS really needs to get on the ball with some updates. I'll even take updates with problems. Anything just to prove they are in fact doing something.
  9. realwarder's Avatar
    Posts
    Global Posts
    3,446 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #9
    Quote Originally Posted by conanheath View Post
    Skype is certainly far from 'the' problem and shows no specific characteristics to make it worse than anything else.
    I have wondered about IE myself as clearly the task never terminates even when you back out of it.
    I was trying to find a javascript counter that simply added a number each second to see if it really ran in the background or was suspended.
  10. TK2011's Avatar
    Member
    Posts
    Global Posts
    380 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #10
    How do you guys know IE task is not terminating?
  11. jimski's Avatar
    Member
    Posts
    Global Posts
    2,259 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #11
    Not sure of how WP8 is working with the 920, but I tried that exact test, keeping the maximum 6 tabs open in IE (a variety of sites, some that auto refresh) on my 900 a few months back. Comparing to my baseline (with no tabs open), no difference in drain.
    Easy to prove. Fully charge your phone "before" you go to sleep. Take it off charge and power cycle the phone and make sure no tabs are open (there shouldn't be any after a power cycle). Go to sleep. When you wake up, note the battery drain, and time. Repeat the next night, this time opening 6 tabs first. Compare results.
    I would do it but I don't own a 920.
    Sent from my Lumia 900 using Board Express Pro
  12. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #12
    Quote Originally Posted by TK2011 View Post
    You can first close down all tabs and back out from IE. Enter IE again, open a web page that auto refreshes and back out without closing the tab. The auto refresh page needs to be the last web page before backing out. You can now start to track how the battery exhausts for an hour or so. Then you can open IE again, close the tab(s), and then back out. Then track the battery for another hour. You should see a big difference.
    Another proof is that when you open IE again, you will see the auto fresh page, take yahoo finance as an example, actually shows the current stock price not the one you checked an hour ago. This means IE was active even you thought you backed out.
    Occasionally, IE auto fresh may malfunction so you may need to run the test a couple times or try different page.
  13. TK2011's Avatar
    Member
    Posts
    Global Posts
    380 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #13
    Quote Originally Posted by w_byrnes View Post
    FWIW, I ran a quick test yesterday and did not see any change in battery life. Maybe it wasn't a right web page to test..
    How do you know the stock quote was not updated fresh just as soon as you opened your IE? Just trying to understand how you came to conclusion that it was running in the background.
  14. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #14
    Make sure that the auto refresh page is the last page when you exit IE.
    It took a few seconds to be updated. When I opened IE, the screen is in a solid view (nothing is being updated) and the time index next to the stock price is current time. My other evidence is that ever since I closed the tabs every time I exit IE, the battery problem is gone. But I understand that the cause could be different for others.
    It is also possible that the auto refresh function is stopped after hours.
  15. realwarder's Avatar
    Posts
    Global Posts
    3,446 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #15
    I stopped all tabs last night but still lost 20% battery so it made no difference here.
  16. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #16
    Quote Originally Posted by realwarder View Post
    Sorry to hear that. It must be something else for you. It may not be a bad idea to send it to Nokia Repair for a check. I almost did that when the dust in the front facing camera made it useless. Nokia will email you a shipping label and it is all free. It may take a couple weeks which is really painful.
    For those who are interested in testing it, you can also use this url: http://sports.yahoo.com/nba. It seems to be constantly reloading.
  17. realwarder's Avatar
    Posts
    Global Posts
    3,446 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #17
    For those who are interested in testing it, you can also use this url: NBA on Yahoo! Sports. It seems to be constantly reloading.
    The same phone is capable of using 0-1% power overnight. It depends on what mood it's in.
  18. sueha's Avatar
    Member
    Posts
    Global Posts
    302 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #18
    I made a test yesterday. How long does it take to kill my battery? My 920 gave up after 38 hours!!! And I used it a lot in that time! IE, Baconit, Games and WhatsApp! I switched on most of the background tasks and am using the 3G network (dont have a 4G data plan). But I have to admit that this is my 2nd Lumia 920. Nokia replaced my first one because of the battery ;)
  19. pdskep's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #19
    There's your problem, quit looking at Apple stock. You phone is punishing you!
  20. socialcarpet's Avatar
    Banned
    Posts
    Global Posts
    1,966 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #20
    I love these threads where people think they've solved the battery "issue".
    I'd say just try to be patient and have faith that Microsoft will get it resolved, whatever "it" is. They are well aware of the complaints and I'm sure they are working diligently on a resolution.
    FWIW, not everyone is experiencing these issues. I haven't had any battery trouble. In fact, my battery life, at least the indicated battery life is fantastic now. If I put my phone on battery saver and use it only lightly during the day, which I sometimes do, I have around 90% still left by dinner time, which is even better than my 900 did.
    I keep Wi-Fi on all the time because I have many places I can use it, I keep location on, I keep Bluetooth off, super-sensitive touch off. Brightness set to low or medium, 4 email accounts, one set to sync hourly, one syncs every 2 hours, the other two set to sync manually.
    Even with moderate to heavy use, it is very rare that my battery runs out before I can get home to charge it. My phone also does not get hot (it may get a little warm if I am playing an intense game for more than an hour, or if I watch a 2 hour movie on Netflix, but thats it. I also use Internet Explorer all the time and leave multiple tabs open.
    I'm not sure what else to say about the battery "issue". I'm sorry some people are having problems, but I do not believe for a minute that it is the norm to have trouble. I'd be willing to bet most people have results similar to mine, they just don't bother to post on a forum about it.
    clubbstudios likes this.
  21. ttsoldier's Avatar
    Retired Ambassador
    Posts
    Global Posts
    4,833 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #21
    It's been said a million times. Battery is hit and miss with WP8.
    Be patient and wait till Microsoft/Nokia releases some sort of os/firmware update.
  22. conanheath's Avatar
    Member
    Posts
    Global Posts
    589 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #22
    Quote Originally Posted by ttsoldier View Post
    I'm skeptical the updates will arrive in time. If we are going to get couple of fixes a quarter, WP8 will always be playing catchup. They are too far behind the curve to nickel and dime updates. I like the OS, but life is too short to be frustrated with a phone that won't perform the tasks to make my life easier. Like I said, I like the OS but in May I have upgrade. If I don't see major improvements, I have no choice but to find something that will meet my needs. I'm sure I'm not the only one either. Their slow and steady approach will see no major gains in market.
  23. The_Traveler's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #23
    I'm on Yahoo! Finance a lot so this seems plausible. Thank you!
    Will give it a shot and report back.
  24. w_byrnes's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #24
    Quote Originally Posted by The_Traveler View Post
    I experienced it again today. When I exited just using the back button and the last page was Yahoo Stock, the phone got heated a little bit and the batteries went down significantly faster. It does not seem to be a problem after hours. I guess the site may stop the auto-refreshing function.
    Again we may all have different causes of the battery draining problem but if you have already tried other solutions and they did not work, you can give this one a shot: before exit IE, select "tabs" in the menu and manually cross out the tab(s). Remember the last page you see before exiting IE is a white/blank page.
    Please report back your findings whether you have solved or not the battery problem using this solution. It may help other people who visit this board.
  25. downhillrider's Avatar
    Member
    Posts
    Global Posts
    244 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #25
    if only someone thought of putting an X on applications so they close properly. I'm sure someone will think of it.
  1. Battery Drain Problem is Nokia Music
    By realwarder in forum Nokia Lumia 920
    Last Post: 05-13-2013, 11:28 AM
  2. Replies: 3
    Last Post: 01-16-2013, 11:56 AM
  3. Replies: 14
    Last Post: 11-18-2012, 02:27 PM
  4. Samsung Focus S problems and my Mango experience...
    By heda_p in forum Samsung Focus S 4G
    Last Post: 11-22-2011, 11:45 AM
  5. Replies: 16
    Last Post: 06-09-2011, 07:20 PM
Posting Permissions
