We made some changes
Our new forums are here!
Saving money on data
Mint SIM is the perfect way to get cheap data in the U.S.
Don't count Windows Phone out just yet
Dead? Psh. Here are 5 reasons to stick with Windows 10 Mobile
VPN vs. Proxy
The difference between a proxy and a VPN
Latitude attitude
Dell Latitude 7280 is a business laptop with tons of consumer attitude
4K all the way
You probably don't NEED a 4K webcam, but we love Logitech's BRIO 4K anyway
Long live Windows phone
Contrary to popular belief, Windows phone won't die anytime soon
XP-YESSSSSSS
Dell's already awesome XPS 15 gets even better in 2017
Surface Pwn 5
Surface Pro 5, Project NEON details leaked on LinkedIn?
Redefining the PC
Why Microsoft's Surface phone could be MUCH more than a mere 'phone'
Surface table meets Windows 10
Yes, we did put Windows 10 on the original Surface table ... and it rocks
Cream o' the crop
Before buying a Microsoft laptop, check out our pick for the absolute best
Simple and secure, just the way I like it
We think Windows 10 Cloud is a great idea, here's why
uber micro
Halo Wars 2 has something for everyone. Here's our full review.
Oldie but goldie
We reviewed Microsoft's decade-old Surface table
Creators Update comin' at ya
These are the coolest new features in the next big Xbox One update (video)
Buyer's guide
The Razer Blade 14 is the best laptop Razer has to offer
Windows 10 app gems
10 terrific Windows 10 apps you should be using
Tower of power
Here's what we think of Dell's XPS Tower Special Edition
Quite a deal
Grab the complete C# coding bootcamp for $41!
Welcome to the Windows Central Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 8 of 8
  1. puredrive07's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #1
    I accidentially tapped the AT&T LTE 1 under this setting and there's no way to deactivate it and just use what ever the default setting is. I do have LTE in my area and my phone was acting wierd at first with connections. Should I be worried? (I'm able to send/receive SMS, MMS, email) What is the difference between the two? Is there a way without doing a hard reset to remove this application from Nokia?
    Thanks!
  2. WorzelGummage's Avatar
    Member
    Posts
    Global Posts
    1,062 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #2
    As long as MMS is working you have nothing to worry about. All the access point app does is allow us to select an access point for MMS, that's it. You should be able to swap between any access points listed by tapping on them but if LTE 1 is working, you can just leave that one active.
  3. puredrive07's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
       #3
    Quote Originally Posted by WorzelGummage View Post
    So this shouldn't screw up download/upload speeds over LTE?
  4. WorzelGummage's Avatar
    Member
    Posts
    Global Posts
    1,062 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #4
    No my friend, it should not.
  5. webwevers#WN's Avatar
    Member
    Posts
    Global Posts
    39 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #5
    I ran across this the same way as you. I accidentally tapped the AT&T LTE 1 and then found out I could not send or receive any SMS or MMS messages. I played around with it and then tapped AT&T 2 and it seems like everything is now working ok. Does anybody know what the difference is? some sort of explanation would be helpful.
  6. webwevers#WN's Avatar
    Member
    Posts
    Global Posts
    39 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #6
    Anyone know that the difference is yet?
  7. Jaripi's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #7
    I have done a custom access point with MMS settings and editable APN .... (just adding one by clicking "add" button there) ....
  8. Lawrence Crecy's Avatar
    Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #8
    Anyone know the settings for a custom ATT access point?
  1. Replies: 5
    Last Post: 02-26-2013, 11:04 PM
  2. How to remove Access Point from settings?
    By onlineharvest in forum Nokia Lumia 920
    Last Post: 01-23-2013, 11:36 AM
  3. Nokia Access point available now !
    By flame l in forum Nokia Lumia 920
    Last Post: 12-19-2012, 03:30 PM
  4. Question about Nokia access point app
    By magictoaster in forum Nokia Lumia 920
    Last Post: 12-14-2012, 01:16 PM
  5. nokia lumia 920 access point is missing
    By zuzelu in forum Nokia Lumia 920
    Last Post: 12-13-2012, 10:03 PM
Posting Permissions
