1. spiderbatman's Avatar
    Hi,
    I am facing an issue. My headphone (the one bundled with the phone) volume during calls is sometimes very low even after maxing it out to 10/10.
    I haven't switched to phone speaker for that time to check if that is low too, but in recent past I have had trouble with phone speaker low volume too.
    The headphones are fine while watching video or listening to audio, but during call (not all calls) the volume becomes very very low.
    Any solution to this issue?
    05-18-2013 03:25 PM
  2. johninsj's Avatar
    How's your signal? You on AT&T/US?
    05-18-2013 03:41 PM
  3. Davey123's Avatar
    I had this problem for the first week when I purchased my phone in November. I finally realized that I was not pushing the headphones completely and securely into the slot.
    05-19-2013 02:07 AM
  4. spiderbatman's Avatar
    Signal is fine.. it is Vodafone/Mumbai-India
    05-19-2013 11:12 AM
  5. VINOTH KUMAR2's Avatar
    1. Open Music +Videos
    Click image for larger version.
    2. Play some mp3 file
    3. Click windows icon.
    4. Now click down volume button and you will see this and Click pause button
    All done
    Now your Bluetooth headset volume will be very clear and loud. ENJOY
    05-22-2013 11:48 PM
  6. spiderbatman's Avatar
    That is some work around for a problem I didn't ask a solution for.. I have clearly mentioned the headset bundled with the phone.. not the bluetooth ones...
    All done
    06-05-2013 04:01 PM
  7. jojapath's Avatar
    I had the exact same problem and what Davey said in post #3 also solved it. Sometimes it looks like they are firmly into the plug but they are not. Just pushing them harder in solves my problem every time...
    06-05-2013 04:59 PM
  1. Replies: 10
    Last Post: 06-16-2015, 02:26 AM
  2. Headset Volume Too Loud during call
    By Sriram Chandramohan in forum Nokia Lumia 800
    Last Post: 04-22-2013, 01:08 PM
  3. Headphone volume very low
    By ryanj04 in forum Nokia Lumia 920
    Last Post: 03-28-2013, 11:22 AM
  4. Call volume - Really low
    By johnnyrussoa3 in forum Nokia Lumia 920
    Last Post: 11-28-2012, 12:17 PM
  5. Video Recording Sound Issue - Volume very low
    By allsabotage in forum Nokia Lumia 710
    Last Post: 06-23-2012, 10:36 AM
