OEM Parts for 920?
ncxcstud
1,147
So - my 920 faceplanted on my floor today - after I filled the hole in the ground, I noticed my screen was pretty much destroyed.
I happened to have an extra digitizer lying around and replaced it. However, it definitely isn't an OEM part and it takes the screen a bit to become 'active.'
Is there a good site that sells legit OEM parts so I can look to get an new digitizer or even a digitizer/screen assembly combo?
Thanks y'all!
gordonfink
1,402
This place seems to get decent reviews:Here.
You might want to check to see if the resistor pattern for the one you pulled off is the same as the one you put on. The resistors are on the tab that connects to the LCD plug. If they are not the same, it won't work the same. This is always a challenge with 920's, because there's about 4 different patterns.
You can also buy a full assembly.
I haven't had any problems with aftermarkets, as long as the parts match.
JoshRos
