1. vonchowder's Avatar
    Im having trouble controlling the volume. I want to keep my ringer off and vibrate on while at work. So I lower it all the way using volume rocker. Then I go to listen to music and I find out that I have to turn the volume up.... it seems this simultaneously turns up the ringer, because I receive a phone call and the music dims down (in my headphones)... so I take off the headphones and pull out the headphone jack and am alarmed to hear the ringer blaring out of the phone's speaker!. Not good while at work.
    So then I end the call and Boom! Skrillex comes blasting out of the speaker as the music suddenly resumes! Again, not good while at work. I was using the Nokia music player to play locally stored music.
    Am I missing something?... I feel like the ringer and the media volume should be maintained separately, and automatic resumption of media after a call interruption is not good.
    05-17-2013 10:59 AM
  2. AlexOwliver's Avatar
    Unfortunately, that's the way Microsoft's done this one. . .we're all hoping for a separation of the two in a future update but for now it's one volume to rule them all.
    I actually like the automatic play on media after calls/interruptions. Feels more seamless to me, but you do have to remember what you were doing.
    05-17-2013 11:17 AM
  3. jaethos's Avatar
    Turn off the ringer with the button in the top right corner of the screen when the volume controls are showing. That way you can listen to music and the ringer won't sound. As for the resume, you'll have to pause the music when you get a call. I like the auto resume myself.
    05-17-2013 11:22 AM
  4. WinPhnLvr's Avatar
    Try going to settings > ringtones&sounds > and set the ringer to off.
    Or, Tap the volume button and then tap the bell icon at the top of the screen. it should turn to wavy lines indicating the ringer is off.
    05-17-2013 11:26 AM
  5. kuyawil's Avatar
    Yes, this is definitely a minor issue for me too. It's not a deal breaker, but I would really prefer to have separate controls for ringer and media as the OP alluded to. The one thing I really liked about my S3 was that I had separate volume controls for alarms, music, video, and games. So, I do hope that Microsoft/Nokia is listening. Let's get this fixed in the next update.
    05-19-2013 12:58 PM
  6. chefster74's Avatar
    I had Volume Control app on my Rezound and it was just awesome, let you adjust 5 different things. So far my only dissapointment, it would be great to have!
    06-02-2013 02:03 PM
  7. remyjette's Avatar
    Also my only real disappointment with my Windows Phone after moving from Android - also hate how you can't have phone on vibrate without making alarms useless. Hope MS fixes this.
    06-03-2013 01:59 AM
  8. GCrane1982's Avatar
    I have my phone on silent every night and even leave my headphones plugged in some nights and the alarm still works through the loud speaker and vibrate every time
    Mandos and hopmedic like this.
    06-03-2013 03:10 AM
  9. Huime's Avatar
    Yea, its crazy right? More so when you see people defend this stupid mistake.
    06-03-2013 03:20 AM
  10. mpt15's Avatar
    My alarms work fine when the phone is on vibrate. I've tried this using the stock alarms app and 627am app. I've tried it on a lumia 620 and it works just fine. At night I put the phone on vibrate and the alarm rings without any issue.
    06-04-2013 02:35 AM
  11. Sanjoy Basak's Avatar
    my nokia lumia 620 was dropped from my hand yesterday. the volume controller button isnt working since then...is it possible to control the volume through touch? or some other way....
    07-10-2013 03:53 AM
  12. broar94's Avatar
    No i don't think so :(
    07-10-2013 03:56 AM
  13. ewphone's Avatar
    Yes! There needs to be a separate media volume and ring volume control! The ringer doesn't need 30 levels of volume control either, it only needs maybe 5. I don't understand why anyone would think that your music volume would correlate with your ringer. What if I had my ringer on full blast and put in headphones? I would get blown away.
    09-11-2013 05:09 PM
  14. broar94's Avatar
    Hopefully added/resolved in WP 8.1
    09-12-2013 04:46 AM
  1. Nokia Free Wireless charger (or lack of)
    By Gmotagi in forum Windows Phone 8
    Last Post: 02-04-2013, 08:40 AM
  2. Nokia advertising (or lack of) - UK
    By Al_2 in forum Nokia Lumia 920
    Last Post: 01-09-2013, 08:29 AM
  3. frustration with apps, or lack there of...
    By bear_lx in forum Windows Phone 7
    Last Post: 02-22-2012, 06:40 AM
  4. Help With Zune/Volume Control
    By DKM-Eby in forum Windows Phone 7
    Last Post: 11-30-2011, 05:27 AM
