Hello all!
I have a lumia 930 with the insider program (slow version). From the last couple weeks my phone started to have some issues. It started with some random reboots when using the whatsapp, then when I was recording a audio msg it suddenly dropped all the battery (i.e, the battery level was at 40%, then I started to reccord the audio msg, battery suddenly drops to 20%, then to 10% and then the phone reboots ~ all of this in a couple of secconds ~ and then when the phone turns on again the battery is back to 40%), and now (yesterday) my phone started to reboot forever when not connected to the charger. It can only stay on if connected to the charger, if I disconnect it, it immediately starts to reboot, goes to nokia screen, then the wp10, and back to nokia, wp10, back to nokia and goes on and on, and when i connect to the charger, it goes all good. I've already done a hard reset and tried to downgrade to wp8.1 but the phone doenst even connect to the pc cause it starts to reboot again when not connected to the charger.
Any clues on what is happening? Is it dead?
Thank you all!
Thank you all!
