As I said before, I was having reboots on my Ativ S, mainly when the data connectivity was being lost.
It is a bug that was once present on the HTC 8X.
I even spend some time creating conditions where my Ativ S will reboot.
Now today, I have some good news! My phone has been up for nearly 5 days now, NO reboots!
So what did I change?
I went through all my apps and deleted all those I hardly ever need. Like ie. Verge reader, Local.ch etc.
Then the remaining apps, I allowed all of them to run in the background.
So, if you have reboots, try allowing all apps to run in the background. If you blocked some and uninstall all apps you don't really need cause you can access the website over the IE browser.
Also, I installed an app called "LastBootUpTime" which allows me to keep an eye on reboots.
Last I switch networks manually before I go to the area where I need to roam on another network.
(Network name issue as it is the same network but under another name, so I don't pay for roaming.)
Try this, I hope it helps.
My Ativ S runs Firmware 2424.12.12.3 on Swisscom in Switzerland.
