1. dynamicdev's Avatar
    Hey guys, I recently bought Samsung Ativ S SGH-T899M and new to WP8. I am really liking new cool stuff except "updates".
    I own Galaxy S2 and always keep it updated. I bought T899 in canada while I was there and now moved to India. As soon as I tried to change network provider, I have been asked to unlock network which I did and now able to use Vodafone India network. However, when I restart phone, I always see ROGERS screen for 2 seconds after which lock screen appears. There are lot of features that is not available to me but on Nokia 920 which is acceptable.
    I would like to know how I can update firmware (my phone's firmware is 2212.12.12.2, which I believe is old):
    1. Via Kies => Kies dont recognize my phone despite Windows 8 OS is recognizing it
    2. Zune too did not detect Ativ S (am I missing driver?, but no exclaimation mark in Device Manager of Windows 8)
    3. FOTA => Always says "phone is upto date"?
    I dont know how I can update firmware. Any suggestion? [/B]
    07-05-2013 06:19 AM
  2. Daniel Ratcliffe's Avatar
    As for number 2, Zune doesn't detect WP8 devices. You instead need to use the Windows Phone for Desktop application, or the Windows 8 app (search Windows Store for "Windows Phone"). As for the other 2, will leave them to someone more experienced.
    dynamicdev likes this.
    07-05-2013 07:30 AM
  3. Exotic Hadron's Avatar
    I believe you don't need anything but your phone and Settings|phone update. Isn't it so? Why would one worry going to windowsphone.com?
    07-05-2013 08:55 AM
  4. dynamicdev's Avatar
    I tried so many times. It does not help. I have asked help throught this post if I am missing anything as I am new to WP8. Should I try after connecting to WiFi network? So far I have tried with Mobile data enabling all options to downlaod in case of mobile data.
    07-05-2013 09:37 AM
  5. Trainwreck_0532's Avatar
    I'm still on that same firmware in Canada.
    07-05-2013 01:08 PM
  6. Matthew Becker1's Avatar
    Hi, Dev. 2212.12.12.2 is the latest firmware version for the Canadian phone, since its hardware is different than that sold in Europe/Asia. Samsung Canada has confirmed that this is the most up to date version. Kies does not work with Windows Phone, so it's not worth keeping, unfortunately. Frustrating, I know, since they advertise it in its product page. Finally, Zune software only works with Windows Phone 7 devices. For Windows Phone 8, you will need either the Windows 8 app, or the application for desktop: Windows Phone app for desktop (Preview 3) | Windows Phone 8 | Windows Phone How-to | Windows Phone (Canada)
    The only way to get updates with WP8 is through Settings in your phone. It's over-the-air only, I'm afraid.
    07-05-2013 02:24 PM
  7. dynamicdev's Avatar
    Thanks Matthew.
    You reply indeed relieved me. I am trying to fix "Internet sharing". Somehow I am not able turn my mobile as wifi hotspot. But the same, I am able to do with my Galaxy S2. After reading various post, I thought my firmware is old and tried to update it.
    Are you able to share internet on Ativ S?
    07-06-2013 01:04 PM
  8. Matthew Becker1's Avatar
    I haven't tried, so I won't be of much help in that area. Perhaps somebody else here can confirm whether they have been successful with this particular model.
    07-06-2013 09:28 PM
  9. neo158's Avatar
    It's due to the hardware in the phone, the T899M is the LTE version of the ATIV S and as far as I know the firmware to fix the Internet Sharing problems has only been released for the i8750 or GSM version. Also keep in mind that if the phone is carrier branded then the carrier has to approve the update before it's pushed out to devices.
    Exotic Hadron and dynamicdev like this.
    07-08-2013 05:33 AM
  10. dynamicdev's Avatar
    Thanks for your reply. Lot of things are now cleared.
    My phone was locked to Rogers which I unlocked. Do you still think carrier's (Rogers) approval will be required in this case?
    07-08-2013 01:22 PM
  11. neo158's Avatar
    Yes it will as the IMEI number is locked to Rogers. It's just like the HD7 I have that was locked to O2-UK that I unlocked for all networks, O2-UK still has to approve the updates for it regardless.
    07-08-2013 01:46 PM
  12. BaritoneGuy's Avatar
    I have the T899 version on Bell in Canada with the same firmware as above and the Internet sharing works just fine for me. I don't use it a lot but I have done it many times.
    07-09-2013 02:28 PM
  13. dynamicdev's Avatar
    Are you on LTE or 4G? I am on 4G and not able to share internet. Somebody suggested to change some APN setting to broadband but APN setting for LTE is disableed. Dont know what to do?
    07-10-2013 12:35 PM
  14. BaritoneGuy's Avatar
    It appears to work on both without issue.
    07-12-2013 12:39 PM
  15. nestben90's Avatar
    Hey guys, I got a Samsung Ativ S SGH-T899M in Toronto, Canada that I unlocked allready but for some reasons there is one of the sim tray missing, I just tray if any of you guys can help me out to find one.
    09-03-2014 05:25 PM
  16. lachutm's Avatar
    There is only one tray for the SIM card, other one smaler is for micro SD card.
    09-03-2014 07:59 PM
  1. The AT&T Locker App not availible on the 8X why?
    By JamesDax3 in forum Windows Phone Apps
    Last Post: 07-24-2013, 03:03 PM
  2. Can't Update App
    By Ramiz_28s in forum Nokia Lumia 710
    Last Post: 07-10-2013, 12:48 PM
  3. Verizon added their collection to the Store
    By despertador in forum Verizon
    Last Post: 07-04-2013, 10:42 PM
