1. campbellc's Avatar
    I would love to hear a review on the S-Pen technology.
    01-07-2013 10:29 PM
  2. jhoff80's Avatar
    The S-pen is a bog-standard Wacom pen, only rebranded. Look for any review of any Wacom-based tablet PC (aka, most of them) over the past decade to get an idea of how it works.
    01-08-2013 09:55 AM
  3. Erandhawa's Avatar
    It works exactly as it should. I haven't experienced any issues, it has very good recognition even with my handwriting (which isn't the best).
    01-22-2013 12:53 AM
  4. angelsimaren's Avatar
    The S pen is a bit small, but that's because it slides back into the tablet with a dedicated slot. The pen comes with a tool that allows you to remove the nibs and replace with new ones if you ever wear them down. I would recommend downloading the Wacom Tablet pc driver. The pen only includes one click-able button, and does not have an eraser; however, the Wacom driver allows you to set the button to be used as an eraser! This is very useful if you use software like Photoshop, Sketchbook Designer/Pro, or even Corel Painter. I have used all three and can confirm it's working and the pressure sensitivity seems to be more accurate.
    campbellc and Coolknight1968 like this.
    01-24-2013 11:25 PM
  1. How is the battery life in this device?
    By Winterfang in forum HTC TITAN II
    Last Post: 11-02-2012, 09:57 AM
  2. How is the screen?
    By mmaman in forum Nokia Lumia 900
    Last Post: 05-24-2012, 08:14 AM
  3. How is the quality of videos recorded on the Titan II?
    By lilb1190 in forum HTC TITAN II
    Last Post: 05-17-2012, 09:06 AM
  4. How is the HTC Trophy a gaming phone?
    By LexusFman in forum HTC Trophy
    Last Post: 04-14-2012, 03:24 PM
  5. How is the screen on this devices?
    By Winterfang in forum Nokia Lumia 800
    Last Post: 02-13-2012, 11:16 PM
