Wifi issues?
fast200
Anyone else having issues with wifi? Most of the time it is great but after being on awhile it bogs down and becomes slower than HSPA+.
danielfilbert
Same as descriped
I have the exact same issues as descriped. Most of the time i only run on mobile data connections, because wifi screws up.
If anyone have heard about a solution, i would love to learn it.
Corepc
1,331
Does it happen when you turn off you cell data connection?
Does it happen with more than wifi aka work, friends, home or just one location, if just one location you could always add the mac address into the wifi router settings..?
mrjamses
I was having a similar problem and Samsung support suggested I reset my router, which seems to work whenever I have the issue.
Carnes
