1. md_minhaj's Avatar
    I have samsung omnia w, I successfully synced my mobile with my gmail account. The problem is some of the contact numbers are not updated in the people hub, What could be the problem ?
    03-12-2012 05:03 AM
  2. md_minhaj's Avatar
    Sorry for posting in wrong category.. can someone please re-direct this thread to correct one ?
    03-12-2012 05:17 AM
  3. palandri's Avatar
    I moved it.
    03-12-2012 06:08 AM
  4. redondo1515's Avatar
    I'm an italian user and I had the same problem. I solved it by changing the "type" of the contact numbers, one by one (you can do that in your GMail website).
    For example, some of my contact numbers were denominated "mobile" and Windows Phone didn't accept that entry. So I changed it to "Home" or "Work"... than, after a new synchronization, I had all my contact numbers in place! :-)
    I hope I was clear enough. Sorry for my bad english.
    03-27-2012 07:11 AM
  5. md_minhaj's Avatar
    Thanks!.. But it will be really tedious task to change category type of every number one by one, if you have hundreds of contacts. Isn't there any other way to solve this issue ?
    07-22-2012 04:22 AM
