For some reason my Focus Flash keeps thinking its charging even when it's not. When I actually plug it in and charge it, it works just fine and charges all the way. But when I unplug it, there must be some software or firmware glitch that causes it to think it's always charging.
On a probably related note, when I connect it to my computer, neither the computer nor the Zune software recognizes the phone. Luckily, I had it set up to wirelessly sync on my home network. But if I'm not here at home, then I can't sync it. And best of all, because it doesn't recognize the phone, I can't update my phone either.
I've considered that it may be the USB ports or the sync cable but I'm almost positive its neither of those because I've tried other devices on all ports and they all work fine, and I've tried my phone on all ports and nothing works. Also, the cable charges the phone perfectly well so I don't think it's the cable either. I've tried tweeting Windows Phone Support and they couldn't figure it out. So I'll probably have to go to AT&T so they can convince me it's something else and never solve my problem. I thought I'd check on the wpcentral forums though just to see if anyone has any suggestions.
Thanks,
rafael913
Thanks,
rafael913
