1. vtective's Avatar
    Has anyone else noticed that in low lighting you can see a red LED on the upper left side of the phone? What is the purpose of this?
    03-23-2011 11:23 AM
  2. cdook's Avatar
    Are you talking about to the left of the speaker you put your ear on? Where the two dot things are? I'm wondering if it's infrared and you can somehow see it? There's a proximity sensor to see if your face is against the screen, to turn off the screen.
    03-23-2011 11:46 AM
  3. vtective's Avatar
    Yeah, it's just to the left of the speaker next. It only lights up when I'm on a call.
    03-23-2011 11:59 AM
  4. fkiehner's Avatar
    One of the holes is the prox sensor that turns off the display when u r on a phone call and the other hole is the light sensor that controls your brightness when that setting is in auto mode
    Sent from my SGH-i917 using Board Express
    03-23-2011 02:46 PM
