1. Zeroplanetz's Avatar
    1 I can't seem to add or find a picture that shows up in my profile pic correctly. I've tried several different sizes and different photos all together. Any suggestions?
    2. I don't know if others have this issue or not but most of the time while using my surface Rt trying to post a thread or a comment to another thread I have to battle with the on screen keyboard to stay up. I've no problems on other sites just wpcentral. ( only thing on other sites is them not really being touch friendly like trying to select a category without having to search.) anyways any suggestions? Thank you!
    01-27-2013 12:00 PM
  2. James Falconer's Avatar
    Zeroplanetz,
    Please email me at james@mobilenations.com and I'll get you setup with your avatar, and take a look at that keyboard issue for you.
    01-28-2013 12:48 AM
  3. eric12341's Avatar
    Yea I also have that keyboard issue on my 8X, it really needs to be fixed.
    01-28-2013 02:57 PM
  4. stmav's Avatar
    Had the keyboard problem with my Surface as well. I think it was Dave Blake that said he noticed it as well, and if he zoomed in there was no problem. That did the trick for me. So when I'm on the Surface, I just zoom a little on the comment box before typing and it's ok. Not a perfect fix, but it helps.
    01-28-2013 05:28 PM
  5. Zeroplanetz's Avatar
    Thank you
    01-28-2013 10:52 PM
  1. Text messaging issue. Could use some help please
    By gresh32 in forum Samsung Focus
    Last Post: 07-25-2012, 10:15 PM
