Why not start a thread so we can post any issues we've had with the Redstone build of W10M:
Build 14267.1004
1) Sometimes after using headphones when the ringer is down, the ringer will show the volume, but still be turned off. - Just turn down volume then turn it up.
2) Sometimes after using headphones: you can't change the ringer volume. Restart may be necessary.
3) Spotify still doesn't detect data over cellular and requires a restart.
4) Store downloads/updates sometimes show 0.1/0.1 and goes up 0.2/0.2, 6.5/6.5, instead of a normal 0.5/6.5 setting
5) Store sometimes crashes upon opening requiring you to open it again.
Build 14267.1004
